I've created an axs file which I can open in a new and saved axp. I add the audio outlet to it and save again. When I try to go live I get this error message. What am I doing wrong??
Generate code complete
Start compiling patch
"RM"
rm -f C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.o C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.elf C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.bin C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.d C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.map C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.lst
"APP"
arm-none-eabi-g++ -nostdlib -fno-exceptions -fno-rtti -mcpu=cortex-m4 -O3 -fomit-frame-pointer -falign-functions=16 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -Wunused-parameter -DCORTEX_USE_FPU=TRUE -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -mthumb -DTHUMB -std=c++11 -DARM_MATH_CM4 -D__FPU_PRESENT -H -IC:\PROGRA~2\Axoloti\app/CMSIS/Include -IC:\PROGRA~2\Axoloti\app/chibios/os/ports/common/ARMCMx/CMSIS/include -IC:\PROGRA~2\Axoloti\app/chibios/os/ports/common/ARMCMx -IC:\PROGRA~2\Axoloti\app/chibios/os/ports/GCC/ARMCMx -IC:\PROGRA~2\Axoloti\app/chibios/os/ports/GCC/ARMCMx/STM32F4xx -IC:\PROGRA~2\Axoloti\app/chibios/os/kernel/include -IC:\PROGRA~2\Axoloti\app/chibios/os/hal/include -IC:\PROGRA~2\Axoloti\app/chibios/os/hal/platforms/STM32F4xx -IC:\PROGRA~2\Axoloti\app/chibios/os/hal/platforms/STM32 -IC:\PROGRA~2\Axoloti\app/chibios/os/hal/platforms/STM32/GPIOv2 -IC:\PROGRA~2\Axoloti\app/chibios/os/hal/platforms/STM32/I2Cv1 -IC:\PROGRA~2\Axoloti\app/chibios/os/hal/platforms/STM32/OTGv1 -IC:\PROGRA~2\Axoloti\app/chibios/os/hal/platforms/STM32/RTCv2 -IC:\PROGRA~2\Axoloti\app/chibios/os/hal/platforms/STM32/SPIv1 -IC:\PROGRA~2\Axoloti\app/chibios/os/hal/platforms/STM32/TIMv1 -IC:\PROGRA~2\Axoloti\app/chibios/os/hal/platforms/STM32/USARTv1 -IC:\PROGRA~2\Axoloti\app/chibios/boards/ST_STM32F4_DISCOVERY -IC:\PROGRA~2\Axoloti\app/chibios/ext/fatfs/src -IC:\PROGRA~2\Axoloti\app\firmware -Winvalid-pch -MD -MP --include C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.h -c C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp -o C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.o
! C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.h.gch
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instanceahw2__1::voice::instanceread__3::dsp(const int32_t*, int32_t (&)[16])':
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:840:43: error: 'class rootc::instanceahw2__1' has no member named 'instancec_i'
int index = asat>>(27-parent->common->instancec_i.LENGTHPOW);
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:841:33: error: 'class rootc::instanceahw2__1' has no member named 'instancec_i'
int32_t y1 = parent->common->instancec_i.array[index]<common->instancec_i.GAIN;
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:841:75: error: 'class rootc::instanceahw2__1' has no member named 'instancec_i'
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:842:33: error: 'class rootc::instanceahw2__1' has no member named 'instancec_i'
int32_t y2 = parent->common->instancec_i.array[(index+1)&parent->common->instancec_i.LENGTHMASK]<common->instancec_i.GAIN;
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:842:77: error: 'class rootc::instanceahw2__1' has no member named 'instancec_i'
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:842:118: error: 'class rootc::instanceahw2__1' has no member named 'instancec_i'
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:843:51: error: 'class rootc::instanceahw2__1' has no member named 'instancec_i'
int frac = (asat - (index<<(27-parent->common->instancec_i.LENGTHPOW)))<<(parent->common->instancec_i.LENGTHPOW+3);
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:843:94: error: 'class rootc::instanceahw2__1' has no member named 'instancec_i'
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instanceahw2__1::voice::instanceread__2::dsp(const int32_t*, int32_t (&)[16])':
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1088:43: error: 'class rootc::instanceahw2__1' has no member named 'instanceb_i'
int index = asat>>(27-parent->common->instanceb_i.LENGTHPOW);
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1089:33: error: 'class rootc::instanceahw2__1' has no member named 'instanceb_i'
int32_t y1 = parent->common->instanceb_i.array[index]<common->instanceb_i.GAIN;
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1089:75: error: 'class rootc::instanceahw2__1' has no member named 'instanceb_i'
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1090:33: error: 'class rootc::instanceahw2__1' has no member named 'instanceb_i'
int32_t y2 = parent->common->instanceb_i.array[(index+1)&parent->common->instanceb_i.LENGTHMASK]<common->instanceb_i.GAIN;
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1090:77: error: 'class rootc::instanceahw2__1' has no member named 'instanceb_i'
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1090:118: error: 'class rootc::instanceahw2__1' has no member named 'instanceb_i'
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1091:51: error: 'class rootc::instanceahw2__1' has no member named 'instanceb_i'
int frac = (asat - (index<<(27-parent->common->instanceb_i.LENGTHPOW)))<<(parent->common->instanceb_i.LENGTHPOW+3);
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1091:94: error: 'class rootc::instanceahw2__1' has no member named 'instanceb_i'
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instanceahw2__1::voice::instanceread__1::dsp(const int32_t*, int32_t (&)[16])':
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1262:43: error: 'class rootc::instanceahw2__1' has no member named 'instancea_i'
int index = asat>>(27-parent->common->instancea_i.LENGTHPOW);
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1263:33: error: 'class rootc::instanceahw2__1' has no member named 'instancea_i'
int32_t y1 = parent->common->instancea_i.array[index]<common->instancea_i.GAIN;
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1263:75: error: 'class rootc::instanceahw2__1' has no member named 'instancea_i'
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1264:33: error: 'class rootc::instanceahw2__1' has no member named 'instancea_i'
int32_t y2 = parent->common->instancea_i.array[(index+1)&parent->common->instancea_i.LENGTHMASK]<common->instancea_i.GAIN;
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1264:77: error: 'class rootc::instanceahw2__1' has no member named 'instancea_i'
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1264:118: error: 'class rootc::instanceahw2__1' has no member named 'instancea_i'
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1265:51: error: 'class rootc::instanceahw2__1' has no member named 'instancea_i'
int frac = (asat - (index<<(27-parent->common->instancea_i.LENGTHPOW)))<<(parent->common->instancea_i.LENGTHPOW+3);
C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.cpp:1265:94: error: 'class rootc::instanceahw2__1' has no member named 'instancea_i'
make: *** [C:\Users\ejr2\DOCUME~1\axoloti/build/xpatch.bin] Error 1
Done compiling patch
Start uploading patch
bin path: C:\Users\ejr2\Documents\axoloti\build\xpatch.bin
FileNotFoundException
Disconnect request
Done uploading patch
Start starting patch
Done starting patch
Start locking
Done locking
Rx paramchange index out of range16 0
Rx paramchange index out of range17 72,351,744
Rx paramchange index out of range50 0
Rx paramchange index out of range51 0
Rx paramchange index out of range52 55,574,528
Rx paramchange index out of range53 57,671,680
Rx paramchange index out of range54 57,671,680
Rx paramchange index out of range55 -25,165,824
Rx paramchange index out of range56 85,983,232
Rx paramchange index out of range57 -50,331,648
Rx paramchange index out of range58 12,582,912
