hi,
i am trying to get a simple stereo Delay of about one second. building them with the delay write and read objects i allways get a slight phase offset betqueen them. it seems to be unavoidable..
i tested serveral things to find the reason:
a mono source at the analog inputs, both inputs get the same signal. after the analog outputs i mix bouht channels with one flipped in phase- so they should null themselfes.
"blank" patch just routing inputs to outputs- no issues- they completely null.
patch with sd ram delay write and read objects- same setting- they. dont null anymore- phase relation has chanced.
patch with only one deleay write object and two read objects reading from the same adress as above: same result, chanels got out of phase...
so it themes to be the delay read object causing the phase issue.. how might this come? no idea how to go on.. i realy need both chnanels to be in phase and delayd about a Second... its so simple task but seems to beimpossible with axoloti...
any ideas?
zimbo
