Hey guys,
Having some slightly confusing issues regarding the behavior of some envelopes, and some “hangs” I’m getting when using the “legato” gate output from the keyb lru device.
Firstly - I’m making patch for use with the OP1, mainly giving it an ADSR and some extra LFOs by sending the curves out via MIDI host. So this could be an OP1 related issue. Not sure.
The main issue is that with all of the envelopes in the community and factory libraries, there seems to be a delay before the attack stage. Almost like the envelopes are all HADSR, if that makes sense. This stops the envelopes from ever being “snappy”, which is frustrating for my purposes. The other strange behavior is that during the Release stage, if the keyb is triggered it snaps the value to the start of the attack value - in a regular synth the re-trig would pickup the value from the falling release stage.
Can anyone confirm if this is the case with them, or if it’s just a problem with my patch/setup?
I also have envelopes seem to “hang” at full value using the keyb lru device, but not the usual keyb device. Another problem using the lru device is that a single trigger input seems to “fire” the envelope through all of its 4 stages, even when the key is let go.
Any help would be greatly appreciated!
actually i might look into that...
