Hey
Finally got Axoloti working. Nice tool
But I think I encountered a bug in the stomp/reverb1 object. When you turn the reverb object on, it seems like the feed of the reverb tilts to the right side. As soon as you turn it off the stereo field slowly goes back to normal. At higher decay the sound first tilts to the right side and the sound gradually fades out.. I feed the same signal to both sides so there shouldnt be any difference.
You can recreate it the simply by adding the reverb to a signal chain and turn it on. Or check the attached patches.
I build a synth and added the reverb and noticed the bug. Then I tried loading up the guitar multi fx patch and I added an osc, an ADSR, a vca, connect them and feed them into the reverb, to check if it was my first patch that was the issue. And as soon as i turned the reverb on, same thing happened again. The feed tilts to the right side.
I am on Mac, OSX 10.9.5, No HUB, Usb cable directly to computer
Axoloti version 1.0.3-0-gc248736
Verb SawOsc Buggy.axp (4.6 KB) Verb SineOsc Less Buggy.axp (4.5 KB)
. Maybe some phase canceling going on in the feedback network? It is almost the reverb first feeds alot and then phase cancels and totally dissapears..... until i turn down the phasor osc. Watch the RME mixer inputs on the right how the input reacts, when I change from cheap saw to phasor osc.
