I keep having problems with my sync, what is happening here?!?
They all seem to be modules which I editted after finding bugs/mistakes..
Sync (pull) FAILED : community (1.0.12,sirsicksik)
org.eclipse.jgit.api.errors.CheckoutConflictException: Checkout conflict with files:
objects/sss/delay/Factotum.axo
objects/sss/dyn/comp1.axo
objects/sss/filter/filterCORE.axo
objects/sss/filter/filterSLAVE.axo
objects/sss/filter/paraMorph.axo
objects/sss/lfo/BPMext.axo
objects/sss/lfo/qtsLFO4.axo
objects/sss/logic/ABchance.axo
objects/sss/logic/countExt.axo
objects/sss/math/glide_multi.axo
objects/sss/math/ratios235.axo
objects/sss/midi/clock.axo
objects/sss/osc/blepped.axo
objects/sss/osc/gausOsc.axo
objects/sss/osc/hrmOsc2.axo
objects/sss/osc/pllOSC.axo
objects/sss/patt/rndPattF.axo
objects/sss/sel/4chanceSeq.axo
objects/sss/stomps/reverbMod.axs
at org.eclipse.jgit.api.MergeCommand.call(MergeCommand.java:419)
at org.eclipse.jgit.api.PullCommand.call(PullCommand.java:331)
at axoloti.utils.AxoGitLibrary.pull(AxoGitLibrary.java:331)
at axoloti.utils.AxoGitLibrary.sync(AxoGitLibrary.java:70)
at axoloti.menus.FileMenu.jMenuSyncActionPerformed(FileMenu.java:264)
at axoloti.menus.FileMenu.access$400(FileMenu.java:51)
at axoloti.menus.FileMenu$5.actionPerformed(FileMenu.java:134)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
Caused by: org.eclipse.jgit.errors.CheckoutConflictException: Checkout conflict with files:
at org.eclipse.jgit.dircache.DirCacheCheckout.doCheckout(DirCacheCheckout.java:420)
at org.eclipse.jgit.dircache.DirCacheCheckout.checkout(DirCacheCheckout.java:402)
at org.eclipse.jgit.api.MergeCommand.call(MergeCommand.java:293)
... 44 more
search path : C:\Users\Dixons\Documents\axoloti\axoloti-factory\objects
search path : C:\Users\Dixons\Documents\axoloti\objects
search path : C:\Users\Dixons\Documents\axoloti\axoloti-contribobjects
finished loading objects
to the directory does not result in a conflict error for me )
