I asked basically the same question in another part of this forum, so forgive me... but I am really at a loss as to why my patch, which simply does looping playback of an audio file, isn't behaving when I try to run it at startup. Here is the patch, which has a play fn stereo going through a couple of paraEQs on its way to the audio out. Super simple. I also included pink noise just for testing purposes.
The patch runs fine in 'Live' mode and when I 'upload to SD card as startup' there are no errors reported. When I disconnect from USB and run the board off an external power supply, my patch runs -- I can verify that with the pink noise -- but the file playback doesn't start.
Can anyone tell me if there is a trick to starting the play fn upon startup? I tried using a loadbang with a delayedpulse to make sure that the playback started well after the Axoloti's startup but that didn't work.
Thanks for any suggestions... I assume that this is not a bug but it definitely is unexpected behaviour.
