During these quarantine days I wanted to catch up with the Axoloti and I decided to go for an Eurorack module for effects processing, and probably I will build another module with oscillators.
As the title says, I'm splitting both line in/out signals, into two mono female jacks and I'm definitely doing something wrong. It happens that if I feed a mono jack into let's say Left channel, I can listen to the same audio on the Right channel but it is very degraded/saturated.
This is how I am connecting
I tried to use the LIN+ and - RIN+ and - and is exactly the same.
This is just my testing patch
Any tip or workaround is much appreciated!!
Cheers
