Split one control to more outs, controlled by switches
Hi!
I can't find an appropriate module for this, can you please help?
I need this setup:
Input: 1 control in (blue), 3 Switches
Output: 3 control outs (blue) - select by Switch on/off which one
So, basically, I want to switch the blue controller input (1 controller) to 3 outs (3 controllers), dependable on the switch input (1 to 3).
With which object can I achieve this?
You need a Hook object. there are a few variants, the best for you is TSG/ctrl/MultiPot 3 this does what you need, there are other options for sending more or less, use the search term hook
the multipot: http://www.privatepublic.de/public/community-objectlist.html#o-1065883761
Thanks, but I can't access these objects, as I see it was an issue also for others
Odd, they appear in my library, is it just this object or all of his contributions, can anyone else confirm an issue with theslowgrowths contributions? The library is case sensitive, tripped me up on a few occasions, hopefully it's just that.
here's the object in the meantime
MultiPot 3.axo (6.3 KB)
Thanks, I reinstalled axoloti, and it seems fine now (I think also some other objects were missing from my setup). Yes, it is uppercase TSG and case-sensitive, but could easily be found now.
I'll try to patch up some switchers.
