Hi folks,
I've dusted off my Axoloti after a year for a play and found I can't compile patches anymore. I seem to be getting a space tagged onto the BDIR path. Here's the error.
Axoloti version : 1.0.12-2-0-g7975cc87 build time : 09/04/2018 13:05:40 UTC
Link to firmware CRC E95BAC96
Status : home : OK
Status: community (1.0.12,anon) : OK ( 1.0.12,clean )
USB device found
connected
Authentic Axoloti Core
search path : /home/mongrol/axoloti/axoloti-factory/objects
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
search path : /home/mongrol/axoloti/objects
search path : /home/mongrol/axoloti/axoloti-contrib/objects
finished loading objects
Generate code complete
Start compiling patch
Compiling patch... with /opt/Axoloti/app/firmware
BDIR = /home/mongrol/axoloti/build\
FIRMWARE = .
make: *** No rule to make target '/home/mongrol/axoloti/build /xpatch.cpp', needed by '/home/mongrol/axoloti/build /xpatch.bin'. Stop.
How is that path set? The build folder definitely doesn't have a space in it.
