Not sure I understand this; You want the reverse to start from the same point as the the forward is located at? So you can scan forth and back over the same snippet pf sound for example?
[solved] Pd sampler.rockafella example on axoloti
I want to reverse from the end of the sample, so just straight playback either forwards or backwards. The problem is I don't know how to set up the phasor probably, I tune it by ear at the moment. This works for forward playback because I retrigger the sample all the time by using the reset inlet of the lfo. But with backwards playback it starts playing out the whole table, instead of start at the point where the sample ends.
I think I need to look into look into the compensation value in on of Jerome's calculations. The problem Is that this value in my case is not fixed, because it changes each time I record a sample.
But maybe it's a good Idea to move this here, I don't want to hijack this thread
I will post some examples there.
Sorry, I had not seen yours replies.
Just start from "length" to zero, then take a reset.
I have change the lfo, in order to have a frequency of 0 if, you want "freeze" the sample. Then, freeze inlet is deprecated.
rockafella.axh (10.4 KB)
rockafella.axs (16.5 KB)
Hanning Window Object
I guess you are using lfo saw lin for this, right? Was wondering if you've figured out what values and data type you need to feed into the freq input? To be able to set a specific frequency?
Thanks
Ha, good question !
First, I don't understand the relation between frequency input of "lfo/saw lin" object and frequency output. I would in this case responded to your question in this discussion !
Then, I trig on reset input of the "lfo/saw lin" object if output exceed the threshold "length". For this reason, the table is read with a different frequency as output frequency of the "lfo/saw lin" object... Sorry.
But I think, it's possible to understand relation between frequency input and frequency of output signal of "lfo/saw lin" object reading the code. I investigates.
Cool. Neither do I. Thanks though. Maybe you hadnt seen the post
dont know much about the coding side of it, so cant help there. But interested in what you find out
For k-rate, a 1hz saw signal must have a 64/3000 = 0,021333 increment (for each step of 3KHz).
In lfo/saw lin object, freq input is divided by 128 :
">> 2 then >> 5 " <=> ">> 7 " <=> " div by 2^7 (== 128)"
If you multiplie your increment (0,021333...) by 128, you have your "freq input" = 2.73.
In fact, 2.73 in freq input means 1Hz signal...
Test.axp (3.6 KB)
Yeah I managed to find out that 1hz is 2.73 by adjusting according to the regular saw lfo.
And by multiplying 2.73 with and ctrl/i with a value of one, you can adjust the frequency by 1 hz at a time. See you have set it up in another way. But this can only go faster that one hz, not slower. Need to sort this out in some way, so we can go slower too.
WOuld also be really nice to have a second value for finetuning hz in less increments than one . So we could adjust to 1.15 hz or 4.45 hz for example and not only whole frequencies like 1, 2, 5, 6etc.. This I havent figured out yet either.
Are you sure ? I think frequency input is a linear input.
Then, if you multiply by 0.273 (instead of 2.73), your "dial p" value means tenth of Hz, no ?
I am at work, I can't try this, sorry.
I think I only said the same as you did; that 1 hz is 2.73.
How can you set 0.273? Or even better, how can you set 0.0273?
A divide by 10 or divide by 100 would be a nice object to have
I missed them a few times
what version are you using this with? currently trying to compile under OS X in 1.0.8 and am unable to use this.
pastebin: http://pastebin.com/g0NzfHPQ
@workerparasite303, I use a from source compiled version. "About" popup says : 1.0.6-2-g1d64bdc
I compiled this version in order to use "ubpatchname/tablename" syntax in another patch. But I don't use this syntax here...
Can you try this :
rockafella.axh (10.0 KB)
rockafella.axs (17.3 KB)
@jaffasplaffa, for 0.0273, I can't with "dial p" object or "*c" object. But it's possible to obtain good result with an increment of 0.027.
Test_2.axp (12.8 KB)
@JeromeB
Thanks for implementing the reverse into your patch and thanks for your effort explaining how to calculate all these values, it is really helpful!
I am able to calculate the LFO Frequency values that I need now thanks to this thread but I come to the same conclusion as Jaffasplaffa: I need to set the LFO more fine, otherwise my Sampleplayack is not in tune
Edit:
Just saw the Test_2 0.027 is not exact enough, my sample playback is slightly out of tune
Is there no way to calculate this properly?
1Hz corresponds to 2.730666 units for "lfo/saw lin"
You can actually type the value when a parameter knob is focused, just start typing the value and press enter to accept. The extra digits will not be shown but they will be used and saved.
Resolution vs. Specific Frequency
@Johannes
thx now I can set my values exactly
So these are scaling values you have to set the math/gain:
1Hz 10,922664
0,1Hz 1,0922664
0,01 Hz 0,10922664
etc.
(it's the 2.730666 x 4 because of the gain object)
Cool!
I don't no. What "thing" ? Test2.axp ? rockafella.axh ?
With rockafella.axh, have you send sound on audio input ?
