[SOLVED] Can't compile patch
Help, I can't anymore compile patches, it's passed sometimes since I had compiled my last one, I have a fresh reinstallation of my SO and now anything seems to work, the axoloti's patch program can't locate the 'make', I'm under windows 7 32bit.
Here the output:
Generate code complete
Start compiling patch
'make' is not recognized as an internal or external command,
operable program or batch file.
Compiling patch failed ( C:\xampp\htdocs\xampp\Sito\pub\axp\bio-involution-2.axp )
FIXED! I had missed to configure the path for the runtime directory in the preference, now it run smoothly!
I'm having this issue as well but I don't understand how you resolved the issue. Can anyone clarify?
Follow instructions for installing runtime here
Note: you only need to change the runtime directory in preferences if you install in a non standard location.
