hi,
so got of my a*** and sorted out some electronics components etc, so I can start playing with axoloti and some diy hardware
first thing I have to do is a AxoControl from @Thonk and @Tombola
anyway, so i do not make a complete mess of it and my axoloti, I'm doing some practice soldering (first time since school!) on a spare copper board. below is my attempt, Ive tested and resistance seems ok, and no short circuits, but would be happy for some advice, and to know if its 'close enough'
ok, top right is a mess, this was 'dropped solder', and I'm really having an issue using a desoldering wick, to get off...
the wick, just doesn't seem to suck up the solder at all... ive tried putting flux on the wick as suggested on YT, but nada de nada. if I could get the wick to work, Id desolder the whole mess and do it again
apart from that...
do the joints look like they have enough solder? any obvious issues?
(I suspect, I'm overheating a bit, as I'm obviously not too quick)
a couple of things I'm not clear on (from videos/guides etc):
a) they say clip the lead before soldering as after can weaken joint, but doing so means I seem to need to bend the leads more, to ensure component doesn't fall out. whereas ideally I think id like the lead to be quite vertical.
(Im using a helping hands to hold it... be careful that the clips dont damage the copper rails)
b) I thought after soldering, the solder was suppose to be visible on the top side of the board, but there is nothing.
but if i apply more solder, it seems to just be on the bottom side of the board.
is this correct, or should the solder be being sucked through?
(I think my solder has flux, as it smoke when held to the iron for tinning etc)
c) whats the best temperature to set the iron to? 700F/375C ?
(Ive tried different from 300-375C doesn't seem to make much difference)
anyway, its a lot of fun, looking forward to building some more circuits on breadboards etc over coming weeks.
(apologies in advance for dumb questions
