Sadly I need to let go of my Axoloti core and I figured why break it apart when the case (while not perfect) and the UI are working well.
- 3D printed case based on the 'default' laser cut case
- 6 pots (10k green Alpha)
- 4 encoders
- 2 OLEDs 128x64 (SH1106)
 *1 three-way switch (on-off-on, connected to 2 dedicated digital input pins so you get 3 choices)
I have custom objects that will let you pick up pot values, encoders, switch value and I can help you understand them.
The OLEDs work with the community library's OLED objects (by user tiar I believe).
100 EUR / 120 USD plus shipping.
I believe the price is more than fair since we all paid high shipping costs to get our Axoloti cores and I'm hardly charging anything for the case and UI parts costs.
Odd color choices I know, I used whatever filament I had to print the case.
Shipping worldwide from Taiwan, however due to the Covid-19 situation, it is YOUR RESPONSIBILITY to make sure postal services in your country work and I will not be held liable if anything goes wrong or your package gets stuck etc.
