if i turn a poti/knob/midicontroller the "digital steps" are quite noticable. how can i smooth that? i was using a micro modular long time back. there are also 127 step controllers but those steps are not there so much audible. of course the mm is more towards a consumer-ready thing + much less objects/freedom ( the reasons why i prefer to use the axoloti) what can be done?
Smoothing controller changes
you could use the k-rate filters for this, but as these are exponential smoothing, you might want to use a linear-glide.
This can be done by using the k-rate filter code, but then just limit the difference between input and filter and add this limited difference to the filter's value.
like this:
int32_t in=inlet_in;
int32_t dif=in-val;
if(dif>freq)
dif=freq;
else if(dif<-freq)
dif=-freq;
val+=dif;
...but could u explain a bit what the above does?...i have no programming background. just try and error and narrow field solutions..
these codes work from right to left, so whatever is put right from the equal-sign, is put into the "holder" at the left.
int32_t in=inlet_in; <=puts the module-input into "in"
int32_t dif=in-val; <- calculates the difference between input and current glide-output
if(dif>freq) <-if difference is larger than the "freq" value, use the freq value instead (only when dif is positive)
dif=freq; <-put "freq" value into "dif"
else if(dif<-freq) <-else, if the difference is below the negative freq value, use the negative freq value.
dif=-freq;
val+=dif; <-add the difference to the glide value so it moves toward the new input value
the "freq" value is calculated with:
int32_t freq;
MTOF(-param_glide,freq)
if you use the simple k-rate lp filter, this is already there in the code and it already uses "val" as the glide-position.
So this code only has to be added after calculating this "freq" value.
If the glide is too fast, just put this in-between the MTOF(-param_glide,freq) and the rest of the code:
freq=freq>>2; (or some other value instead of two.. the bigger the value, the slower the glide)
oh sorry, I just see that "freq" is just called "f" in the k-rate lowpass, so just write "f" instead..
this one would perform better as I just found out:
int32_t freq;
MTOF(param_freq,freq);//calculate the "norm" glide rate
if(!(in==inlet_in))//update rate when input changes in comparison with last position
rate=__SMMUL(freq,inletin-val);//calculate needed change-rate
in=inlet_in;//update the "new position"
int32_t dif=inlet_in-val;//calculate the current difference between glided signal and input
dif=dif>0?dif:-dif;//fully rectify the difference, so it cannot go beyond the new position
if(rate>dif)//if the rate is higher then the difference between glide and goal value
rate=dif;//use the difference value instead of the rate to prevent it from going over
else if(rate<-dif)//if the rate is lower then the negative difference between glide and goal value
rate=-dif;//use the negative difference value instead of the rate to prevent it from going over
val+=rate;//add the rate to the current gliding value
outlet_out= val;//output glided value
ok, one problem it seems... the function:
___SMMUL(....,....) can't be written down in this message box using a name with another underscore in it..
so I'll try writing that part on multiple lines here
rate=__SMMUL(freq,
inlet_in-val); //calculate needed change-rate
i just came back to this and now startet testing. i had put your code in a duplicate of k rate low pass flt...and replaced the existing krate-code with it but like this it doesn't compile. low pass and smooth object already are quite effective...i still would like to use your code....its the first object where i start changing things inside ( though i do have arduino experiences)...could you give me some more advice how to get it working?
the problem is that the textbox overhere mashes up the text when you use multiple underscores. So I can't really exactly write what you need to do, as it will just show up wrong. Go through the text to find the messed up words.
eg.
rate=__SMMUL(freq,inletin-val); should have one more underscore in front of it (3 underscores in total) and one between inlet and in
also, you need to declare "rate" like I declared the int32_t freq;
how or where do i declare "rate"?
i see, if i type, rate=__SMMUL(freq,inletin-val);
in here it had swallowed 2 underscores...
why is that? ...but if one knows it...
seems i found the answer myself...
it compiles ..but doesn't work.
i put in the krate code at the beginning...:maybe not exactly correct...
int32_t freq;
int32_t rate;
int32_t in;
you don't need the "int32_t in;"
as the "in" was part of "inlet_in".
so now you're probably trying to get a value from something that isn't used.
i read:
In member function 'void rootc::instancelow__1::dsp(int32_t, int32_t&, int, int)':
error: 'in' was not declared in this scope
if(!(in==inlet_in))
i am learning...
what is wrong?
