Slow lfo for audio loop disintegration?
Hi, i am fairly new to Axoloti, so excuse if this seems obvious or something...
I've build myself a hardware controller with 5 buttons and 15 pots.
The patch which i am working on should get you the basinski disintegration loops vibe.
So i patched a looper going into some fx eg. some nasty distortion and some white noise.
What i would like to do now is to push a button and start a slow lfo with that button that sets the amount of distortion.
I got the lfo doing its thing, but i can't figure out how to start the lfo with a button.
Hope you guys know what i mean since i don't know how to explain properly.
Basic question is: how can i start the loops destruction???
Other solution would be to slowly increase distortion with each repetition of the loop...
Please help, i am absolutely clueless...
sounds like you just need a mux and a toggle switch, if you simply want on/off modulation....also check out the patch and video in this thread for another Basinski style looper
thanks, works perfectly.
Couldn't think of this simple solution...
