almost forgot to save these as they were quick custom modules for a project
NEW MODULES
DIST
"RingMod"
ringmodulates 2 inputs and mixes the outcome with the inputs
wet/dry level can be set for both inputs and ringmodulated signal
4 modes for ringmodulation:
1: A*B
2: A*A*B
3: A*B*B
4: A*A*B*B
has an input-gain saturator for the ringmodulation for when using weak signals and adding more higher harmonics/distortion
FILTER
"6dBresLP"
6dB lowpass filter with resonance.
resonance has it's own LP and HP filter in it's path, so it's frequency can be offset in respect to the cutoff frequency. Also it's width can be set.
Seperate modulation inputs and modulation-width controls allow for different responses for cutoff and resonance to the modulation inputs.
A saturation function keeps the resonance within bounds and enable screaming filter resonances.
