NEW MODULE
PATT
"rndPatt"
random pattern generator with repetition control dividing the incoming (maximum) count into smaller parts.
each time a trigger is received, positions of the pattern will be randomised or not, depending on the change parameter (in percentage, so 100 is randomising the whole pattern when triggered).
Connect a control to the "length" input to set the total length of the incoming count (eg use my counter, where the max-control is controlled externally and use that max-control to control both modules' length).
With the length-parameter you can set a division of the total length, repeating only a part of the random values.
eg. set max to 8 and the length-knob to about 21.00 and you'll get a 1,2,3,1,2,3,1,2 repetition.
The chance-parameter sets the chance that any position in the pattern will be randomised when a random-trigger is received.
The pattern will be newly randomised each time you start up your axoloti.
