Simple midi looper?
Hello!
im trying to build a midi looper with rbrt's mloop objects.. have anyone used these ? there is no help patches with these.
im stuck in the very beginning, dont understand what are the "index" things, what am i supposed to connect to them.. and what kind of tables i should use
im trying to do a very simple midi looper that would just record a loop and loop it with overdub function, and some kind of erase function.. i dont need sync, quantization or anything like that.. or is there some better way than these blocks ?
I haven't used it yet, but if you want to live loop it, you'll want to try connecting some sort of counter to the index input of the play and rec objects. One example would be connecting a square lfo to a logic/counter that's set to 16, then connect the green out of the counter to the index ins of those two objects. Otherwise you can use a midi clock object (from internal or external source).
Someone can correct me if I'm wrong, but I think you can save space by using an 8 bit table since your note values are going to be within that range, and your size only has to be as big as the number of steps you're using (16 steps = size of 16).
It looks like the write and record objects work similarly but the write object just has the counter built in (you'd connect the lfo directly to the trig of the write object).
Also since you're looping, you can connect the same toggle to both the 'rec' and 'play' inlets of those objects. This is all guessing from looking at it, but I hope that helps.
Oh, also, connect a logic/change from the green 'note' out of the play object into the 'trig' inlet of the midi out object.
I remember a recent post of MattilynMattroe...
Midilooper all options..
Here it is:
