Im a newbie at electronics but getting interested in messing with some hardware, based around independently powered 5v circuits. messing with things like hardware oscillators.
my questions really is how to control these from axo and convert between axoloti 3.3v and the 5v levels , in a simple (=few components) way , also baring in mind, I might have multiple axos connected to the same 5v circuit.
(the discussion on Eurorack seem to be quite complex, and possibly overkill for my simple circuits)
Ive done some research and wonder if the following is viable, what the issues are etc
a) axo analog/digital -> 5v circuit
grounding - I assume I connect axo GND to circuit GND, if im using multiple axo to the same circuit , then connect all their GNDs to its GND.
i) direct connection, is safe but I only get 0-3.3v
(do I connect a diode (normal type?, size?) in line, to protect if I accidentally connect the circuits +5v to it )
ii) level converter - https://www.sparkfun.com/products/12009
(axo VCC to LV, circuit +5v to HV)
iii) simple circuit to scale 3.3v to 5v?
b) 5v circuit to axo analog/digital
again, common ground between all devices.
i) simple resistor divider... e.g. 3/5 ratio,
I get that using higher resistor values increases impedance, but no idea what values are reasonable
i.e. why use 10k vs 10m?
... also I guess there is an issue getting 'exactly' 3.3v due to tolerance, and standard resistor values, can i use a trim pot to get close enough
c) audio in/out is anything special required here... as its low voltage anyway, no?
i guess with this kind of 'cv' control getting full range and linear behaviour is perhaps an issue.
but Id assume I can calibrate this with a 'curve' in software in the axo, for both in/out.
or does this not work, due to other physical issues (e.g. temperature?)
the level converters look attractive as a simple solution, any downside - im not doing production runs, so they are cheap enough for my usage
sorry, I know all this is really basic stuff, but as a software guy, hardware is a mystery
any good book recommendations?
im ok with ICs, and basics of what resistors/caps... but look at amazement at guys who say 'you'll need a 1ohm resistor there, and place a 1uF cap there
thanks for any thoughts and pointers
Edit: so looking more at this...
seems logic levels are one thing, and continuous levels another. I'm wondering now if to use vactorals for the later , though they seem to be expensive, but have advantage of isolating the 2 circuits. ( are phototransitor optocouplers only for logic circuits? )
( I'm guessing vactorals are slower but that's not an issue).
, you will need to convert. If you are trying Analogue Axo out to 5v Analogue in, this may affect your analogue reading, but you may have the option of of an Analogue voltage reference on the 5v side to account for the 3.3 v reference that can be connected. And if they all come from the same power source, connecting the GND's should not be an issue if required. To be safe, I have made a "Y" USB cable I split into 2 connectors so I can be sure they are definitely from the same power source, then I won't need to question any adapters and USB power supplies etc. Logic converters work, there are some unlike the sparkfun one that are by-directional and have more inputs, I try to ensure I have considered other alternatives as I find them a little fiddly to work with, but that is just me I guess.
