hello
i know this topic has been covered before, but i've followed all the previous suggestions to solve the problem and none of these have worked.
i'm running axoloti on a deiban 64-bit amd system.
i've installed the following dependencies:
lib32ncurses5_6.0+20161126-1+deb9u2_amd64.deb
lib32z1_1.2.11.dfsg-4.1_amd64.deb
libbz2-1.0_1.0.8-5_amd64.deb
in the axoloti preferences all my directory locations are correct.
and here is the output from the axoloti terminal when i try to run a patch:
Generate code complete
Creating directory on sdcard : /01_sine_oscillator
Done creating directory
Changing working directory on sdcard : /01_sine_oscillator
Start compiling patch
Compiling patch... with /opt/Axoloti/app/firmware
BDIR = /home/jason/axoloti/build\
FIRMWARE = .
make: *** No rule to make target '/home/jason/axoloti/build /xpatch.cpp', needed by '/home/jason/axoloti/build /xpatch.bin'.  Stop.
Compiling patch failed ( /home/jason/axoloti/axoloti-factory/patches/tutorials/01_sine_oscillator.axp )
many thanks for any help on this.
