Just a patch example of a sequencer i made for my project.
Its quite simple :
stepSequencerV1b.axp (40.7 KB)
-In record mode you can input notes with your keyboard in step by step mode, you can also insert REST (old school step by step sequencer).
-You can edit steps and insert a note anywhere defined by the step selector. Selecting a step with the radio control play the selected step as well.
-You can transpose sequence and change the number of step.
-you can save preset and load preset on SD card (you have to select a preset number)
-The sequencer is not triggered by a clock but by user input using a midi key for example. This is because i am using a version of this patch with my drummer who do not want to play with a click
So you have to send a gate signal.
