SD card and sensel morph
I imagine what I'm trying to do is quite simple, though I cant do it so...
Im trying to get two patches loaded onto my recently formatted but never before used sd card, which I intend to programm a midi CC patch change to switch between the two patches so I can play the axoloti patches with my sensel morph, without having to use a computer.
The current issue Im having is that if I set patch to upload to sdcard at startup, or have the sd card inserted at all, it disables the morph - if I restart without the card in I can access a patch in flash but with the card inserted Im getting neither morph or patch loaded. What am I missing?
So if I remove the start.bin file it doesnt knock the morph out, though no patch loads from the card... it wasn't anyway. Is there a way to achieve what I want? ie morph connected with a patch loaded from sd card and live?
Did you format the card with the util/format object from that patcher app?
Nothing else comes to mind, it works for me
I did - formatted fine, can see files in the window etc... It will definitely be something simple - I'm rubbish at all this! Do I need to put something in the SD card enabling a class compliant mpe device or something like that? Or a setting to make the patch live?
There is a couple of ways to change patches, Midi program change, using the two small Axoloti buttons...
a search on this community always a good starting point :wink:
Yes, I've searched and found thanks, though the issue I have before I can get to that is that loading from the SD card knocks off connection to the morph.
Edit: And by that I means Inc an SD card in the axo on boot disconnects the morph.
ummm, what SD you're using? what patch is first loaded? can you tried with another controller? other SD card?
Samsung thingy, formatted with axo control block thing. I could try with my linnstrument too... Even when I unplugged and replugged the sensel it still didn't appear to have a patch loaded. All fine without the SD in - plays from the flash memory without issue.
more info... size, speed; there is a post about SD cards...
Do a couple of change/swaps, (ohh LS!!) with perseverance you'll get there :wink:
Card is a 32gb sdxc uhs-i card, 80mb read, 20mb write.
Ill have a look for the thread on cards as 32gb is overkill for my needs anyway...
I've ordered a slightly quicker sdhc I'll try...
Could it be something to do with the filename? I'm not familiar with 8.3 but I'm pretty certain I didn't save the patch to the card in 8.3.
Steps forward...
I've got it loading a patch and keeping the morph connected - I can now load a patch in flash and change it by enterring the card. Next step is patch changng, which I've begun but so far failed - as a start point Im trying to use the buttons on the axo to switch patches... more trying/searching later...
I should have also asked about what version of Axoloti firmaware/Axoloti patcher you're using?
Good question... a very old one it seems!
no worries... Im on "old" one as well, I did try 2.0... not there yet.
Updating now, or at least trying to - nothing seems particularly easy in axoloti. Its a great device but getting it where you want is more a PITA than I'm used to or expected.
you don't have to :wink:
takes some getting used to; but this forum and users can help.
This post is getting long but maybe it's just a case of some planning ahead:
* patch change
* what "produces" the change
* if using USB MIDI - patches have to address this :wink:
Just a few ideas from top of my head...
At this point I'm not sure I have the right firmware in my axoloti core? It's showing as:
Authentic Axoloti Core
Firmware version: 1.0.0.1
Software wise I'm: Axoloti version : 1.0.12-2-0-g7975cc87 build time : 29/11/2018 14:38:54 CET
I'm perhaps wrongly assuming the versions should match?
Meanwhile I can change patches and presets, but am yet to figure out controller objects. I've things to try but I'm partway down a frustrating rabbit hole... it's quite the hackaround. I assumed it was my rubbish computer skills but am reassured by someone who has the skills that for the most part it's not elegant.
OK, so I think I have the right firmware, back to it...
