SD card and sensel morph
#21
sorry had to leave..
yeah, all good, Im on the same firmware/Axoloti Patcher (editor)
ohh plenty of posts/info around...
This might help?
#22
Thanks that's helpful - I think the problem I have is that can't seem to get a controller object to run on a blank patch. I've added a directory:
local controllers C:\Users\Andy\Documents\axoloti\objects\
checked the enable controllers and saved a test file that runs when I make it live in normal use, but nothing.
I've got a friend on the case so hopefully he cracks it...
#23
??? why this?
The so called "controller object" is just a patch with the patch change mechanism...(and its directory) if this makes sense to you.
#24
this is my patch = patchchangeall.axs
allows MIDI program change and use of the two tiny buttons on Axoloti itself
this file/patch "reside" similar to your C:\Users\Andy\Documents\axoloti\objects\
correction: dir should be: C:\Users\Andy\Documents\axoloti\objects\controllers
#25
....then in Preferences add this: (don't use the file extesion .axs)
#26
Thanks for the help.
The blank patch was just to see if the test patch I made was compiled into it - wasnt though. I'll try with that extension...
#27
A quick question - does my axoloti core firmware look right to you?
#28
Yes, your software and firmware are the best stable versions.
Here's what I see on startup:
Axoloti version : 1.0.12-2-0-g7975cc87 build time : 09/04/2018 13:15:31 GMT
Link to firmware CRC E95BAC96
Status : home : OK
Status: community (1.0.12,anon) : OK ( 1.0.12,clean )
USB device found
connected
Authentic Axoloti Core
search path : /Users/me/Documents/axoloti/axoloti-factory/objects
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
search path : /Users/me/Documents/axoloti/axoloti-local/objects
search path : /Users/me/Documents/axoloti/axoloti-contrib/objects
finished loading objects
#29
Update time...
I used keyman's patch in both versions of the MPE patches - I have patch loading from sd, buttons switching between two patches and he morph playing nicely, hurrah!
Today's job is to add in a preset select patch a friend passed on, and then get the patch select into a controller object - currently its not loading the file path though I've been given a clue as to why (file extension apparantly - its not recognising the ones given here as it should do, but seems it might if I remove the users\andy\axoloti part).
Ultimately though I'm where I wanted to be and now I'm trying to get set up a little better so I can take things further... Thanks for all the help folks!
#30
Slight error in post above: removing 'objects' from the file path worked for my friend.
It isnt working for me though - can't seem to get loading controller objects working at all, despite apparantly pointing it in the right place i get:
Using controller object: controllers\changepatch
Unable to created controller for : controllers\changepatch
