I'm modifying my simple 8 voice sampler which I have been using for sometime now. It is an 8 voices monotimbral sampler with an audio input for another instrument for live situation (my dx100 audio and midi go to the Axoloti, then I used a usb midi controller to switch between the DX and the Sampler).
I'm adding an arpeggiator, I'm using @cpwitz arpeggiator module, it will be affecting the sampler itself but also be able to mirror its output to the midi out to control an nord micro modular.
I have a few questions:
Does the arpeggiator needs to be inside the Poly voice from my sample or can it be outside with inlets as pictured here?
Does the switching (controlled by midi) for the on/off of the arpeggio make sens? I'm switching between the classic midi in and the arpeggio, I'm not sure this will work if I want to keep the pitchbend control active.
I want to control some integer (green input) values via midi, can I use a F controller and map its range?
thanks
best
K
