Hy guys,
it's about controlling more effects for my guitar using the same potentiometers. The idea is to control a parameter of one effect (f.e. a mix) with a potentiometer. When the rotary switch is on the second position the very same potentiometer should control a different parameter. In short: i wanna control more parameters with one single potentiometer.
Example:
Rotary on pos 1. > Potentiometer is controlling Parameter 1 of effect 1
Rotary on pos 2. > Potentiometer is controlling Parameter 1 of effect 2 ... and so on
I couldn't find any post which pushes me on the right way, so sorry if bothering: maybe on of you can give me an idea how to get the integer into changing the CC.
I've found very useful posts to get the rotary to an integer and to control the parameter with my poti. But how can i connect both concepts. Sorry, if this is maybe already solved an i'm to dumb to find it.
Thx for your help!
