Reverbs creation
another +1 for vahalladsp reverbs, love them all
ooh, lots of information to digest in this thread... keep it coming, some good late night reading !
@jaffasplaffa , axoloti allows you to write your own objects, so anyone with the relevant experience could write this today.
(reality is, its probably not C/C++ experience thats the hurdle, but the DSP/maths
I hope the object editor/community library will expand the object base outside of what johannes has time to write.
about convolution:
Possible but nowhere going to be close to an efficient solution, this needs a dedicated object. In fact I developed a draft in the meantime that does 1024 sample direct convolution at 68% load, which I'll share when it's ready.
That will not scale up to much larger impulse responses as the load scales linearly with impulse response length (unlike FFT convolution and partitioned FFT convolution, they deal much better with long impulse responses, but those algorithms are much more complex to implement and I'm not sure it is possible, and I have no current plans to develop this). It is a solution for speaker cab modelling or adding "instrument body" resonances, but not for reverb.
In contrary, almost all filters in the object library are IIR.
A good didactic resource on artificial reverb is
https://ccrma.stanford.edu/~jos/Reverb/
Cool thanks guys
Yeah some good info here
I wish I had that skill, then I would be all over it. Anyway, Axoloti can do so much al ready, with all the low level objects. In the beginning I asked you guys a lot for new objects, but I know you have enough to do and at the moment are focusing on other things than objects, so I just try to work with what I have, efficient or non efficient
Anyway, it is also a learning process, figuring out how to create effects in different ways and just working with dsp in general
Sounds pretty awesome. Cant wait to see what that can be done with it
I've been intending to build a rough Lexicon reverb clone in Axoloti since I found this talk that Tom Erbe gave on the process of designing the Make Noise Erbe-verb.
It's extremely useful as he goes into pretty great detail about the history of feedback delay network based reverbs & demonstrates various different topologies (including one from a classic Lexicon verb) and talks about the relative advantages of each (& the reasoning for those developments).
Thanks for this reminder about Tom Erbe. I love and use his plugins alot. Found this paper about Erbe-Verb:
http://quod.lib.umich.edu/cgi/p/pod/dod-idx/building-the-erbe-verb-extending-the-feedback-delay-network.pdf?c=icmc;idno=bbp2372.2015.054
which inspired me to build this FDN reverb (Erbe-Verb utilizes cortex m4 too, by the way)
FDN-Demo.axp (97.5 KB)
Feel free to modify it for optimisations and improvements. I wouldn't mind against proper infinite sustain for example
Slightly optimized update (eats 29% CPU)
FDN-DemoUPD.axp (94.5 KB)
March 2016 - Effects Patches (challenge/discussion)
I looked at this FDN reverb and it looks good. Having only four lines in the tank (the part that generates a reverb tail by feeding back the signal on itself) is a bit low, but understandable considering the limitations we’re dealing with here.
The only thing that I would have done differently would be to have a series of allpass filters placed before the main reverb tank; by having five to ten all pass filters (filter/allpass.axo) in series before the main tank, we can smear percussive transients so that they do not rattle in the reverberant tail. Another way to smear the transients is to use a short noise burst in a convolution; even a 10-30ms noise burst convoluted should reduce or eliminate the rattle of a percussive sound before it hits the main reverb tank. I don’t see a convoluter in the objects, but the CMSIS library ARM made and included in the main Axoloti distribution has a few optimized convolution libraries.
I also find it interesting that all four lines in this FDN tank have the same initial delay time, but, of course, since they are modulated differently, they end up having different delay times.
Also: While the Schroeder reverberator is frequently published in the academic community, it’s almost never used commercially. It tends to sound metallic and unpleasant; even the highly optimized “Freeverb” Schroeder reverb (which probably sounds as good as a Schroeder can) doesn’t sound that good to my ears. One good starting point is the Griesinger-based (that means Lexicon) reverb algorithm (the “figure eight” design), which became a matter of public record back in 1997: https://ccrma.stanford.edu/~dattorro/EffectDesignPart1.pdf
Thanks for your feedback and this tutorial, interesting read. I suspect, Jon Dattorro is responsible why my ensoniq dp/2 sounds so good.
Another thing: Reading Erbe’s paper, I observe that his FDN has an allpass before each delay line in the FDN tank, but you design seems instead to have a highpass filter instead of those allpass filters right after the lowpass filters (and before the delay lines). Also, there is a FDN4 object (reverb/fdn4.axo) but it does not appear to have modulated delay lines in its tank, so it should be more static sounding than the tank you made.
There are 4 patchers right after hipass filters. Each patcher contains 2 xfading allpass filters with different delay times since we can't modulate them (yet).
Module requests
Thanks for pointing out that those allpasses hidden in the patchers in the middle of the FDN tank.
I wonder how much the sound will suffer if we just use static allpasses in the reverb tank, compensating for that by using a six-line FDN instead of a four-line FDN and by putting 10 static allpasses in series before the main FDN tank.
Time for me to get my own Axoloti and find out for myself.
this is sounding pretty lush! using it and comparing it to @kausto's effort - very different reverbs!
ill probably end up using the Schroeder for a lot more sounds, but the Keith Barr reverb lends some really interesting textures to standard house/techno sequences
i cant get either of these to open in the latest release :[
Thanks @kausto for your reverb patches, I'm really enjoying them, they sound very nice. Great work
I made more hi-fi version with improved modulation section. It consumes 42%CPU and almost whole SRAM
LushFDN.axp (93.4 KB)
Wishlist of objects
https://clyp.it/vb4bfvw0
Little example (made with more early version which had improved sound engine but non-improved modulation section).
Synth1 VST is sequenced in Renoise being sent to Axoloti and then returns back into Renoise.
https://clyp.it/sh0bo2rl
This one was made with latest version. I'm pretty impressed
Amazing! Sounds really great. Insert a pitch shifter in a feedback loop and you would be in Brian Eno heaven!
