Yeah the reason to want this was actually to try to avoid using preset manager or use the PExParameterChange function. The param exchange function is great for sequencers you only need to use one of them for a whole sequence. But using it on everything, can be a bit tough on Axoloti.
If you could simply have a reset button that reset every parameter of an object it would be a lot "cheaper" for simpler setups...... I think
Cause the function is already there and the values etc are all ready set in the editor, you simply just need to trigger it.
Will see, I might try again one of the days. Have learned a little bit more codewise since i tried last time
