Reflashing with pre V2 software
Hi all. A while ago I got over-excited and flashed the v2 software onto my axo. I understand it's still pretty beta, and really want to go back to the stable release. Are there instructions for going back to the old version? Is it straight forward? WAnted to check whether others had done it before just fiddling around myself and breaking something! Thanks.
Remove everything from the v2 software, and install v1 again. You should get a "firmware mismatch" dialog which will let you install v1.x firmware on your board again.
If the firmware installation doesn't work with this process, you can try the rescue flash from within the v1.x patcher. Described here:
