I want to create a polyphonic drone instrument where each voice can access a vector of say 8 parameters.
Each voice to be to be dynamically controlled by that set of parameters.
This vector of parameters is dynamically generated by data coming in from external sources, so I can't set it as preset values in sub patches.
I could imagine configuring the voices via monophonic patches, one for each voice, this is the solution I've seen used in PD where an array like object can be injected. Then each mono patch can have inlets for the parameter values.
Is there a way to tabulate the data in a parent patch, then get the individual voice patches to read their own values?
