Random object behaving non randomly
hi there, i have made some changes to the formant synth from the cpwitz library. i encountered a strange issue though: the random generator on the main patch, always outputs 0 2 4 6... not random at all. if i change n while the patch is running, it seems to be fine, but when i go back to n = 8 it is not random anymore. sometimes it is also 1 3 5 7. can somebody confirm?
this also happens with the stock formant-synth from cpwitz.
creating random uniform in a separate patch works without problems, so it seems to be dependent on some other objects.
find attached my patch that shows the issue.
formant.axp (4.9 KB)
I'll address this issue in the upcoming release.
