Not sure if this question has been asked as cannot find anything similar, I am about to start mounting my axo into an enclosure fully enclosed and I want to be able to see the activated LED's during the changes, is there another solder point on the circuit board accessing the LED behavior that I can use to extend these out ?
Apologies if I am repeating this topic..
Question about the active SMD LED's?
There are no solder points available for the LEDs, board space is very constrained...
You could solder a bodge wire to the resistors that limit current to the leds (right behind the leds).
Or change the pin mapping in in the firmware (axoloti_board.h -> LED1_PORT etc), recompile and flash firmware...
Thanks Johannes,
Think I'll try the bodge wire to the resistors, I'll leave the awesome firmware work to you guys.
Looking at the schematic and the firmware sources, I can't see any problems using 2 different LEDs and another SW2 connected in parallel (if I'm wrong, please correct me). But I can't see any way, to put the BOOT1 signal in to another switch. It's connected to PB6 and there is a definition in the firmaware SW, but no reference. Is that correct, that BOOT0 (or SW1) is hardwired into the chip? Or is there a chance to use another pin in parallel with the same effect?
I'm using axocontrol, so I guess, I can use PC0/PC4/PC5/PB6 and PB7. They seem to free.
Done! The code was easy to change and adding a bodge wire to SW1 was no big deal. With the new FW, I have now SW1,SW2, LED1 and LED2 outside. If someone wants the new FW or the changed source, send me a message.
If there are other means to publish my changes, please tell me.
Can also confirm LED's can be extended quite simply tapping into one end of the SMD (tiny soldering reqd) going into the base of a switching transistor then powering the LED's, in fact this way the SMD's do not light up at all, only the externals.
