Hi!
I'm making a patch with a two 10k potentiometer joystick just like this one:
It works fine, but it only uses half of its capacity movement wise. When i leave it untouched I get both signals at half capacity, that works as intended. But when I move whichever axis I only get to move it halfway before I reach the full signal (or zero, depending on which way I move it).
I hope you are understanding what I'm trying to say, english is not my first language and I lack vocabulary in this area.
So my question is, those of you that have used joysticks (like this one or similar), have you had the same problem?
Did you solve it somehow, or you just left it like that?
Edit:
I just made a drawing of what I'm trying to explain. The yellow circle is the joystick's full movement, while the green circle is the zone that gives useful values. Over the blue lines, the values I get.
Glad you sorted out the cause.
