I'm just wonder what will wear the least on the internal flash mem.
- Upload to SDcard as startup
or - Upload to internal flash
I wonder what actually happens when i do Upload to SDcard as startup? Will it then flash the internal mem with the patch file from the SD card every time i boot up the Axoloti in standalone mode? Taking one of the 10 000 write cycles on each boot?
I guess if i flash the internal flash mem from the Axoloti patcher it will only do that one time when i flash it, then only read from the flash mem on every other boot-up in standalone mode.
also what about samples and tables i guess they are stored in different memoey... SDRAM? no need to worry about that right?
Thanks
So it is the firmware updates that wear on the flash?
