For previous work on Cortex-M chips I wrote a Python based SWD debugger: pycs
Now that I have an Axoloti board I have added it as a target and find it useful to poke around and see what the firmware is doing to the chip. I connect to the board with an STLink V2 dongle.
It uses the CMSIS-SVD files to decode the SoC peripheral registers.
The target specification adds the Axoloti specific IO and SDRAM.
If I can work out how to make the codec talk to me, I'll add some register dumps for that as well.
$ ./pycs -t axoloti
pycs: ARM CoreSight Tool 1.0
STM32F427xG: compiling ./vendor/st/svd/STM32F427x.svd.gz
ST-Link usb 0483:3748 serial u'P\xffj\x06IgSV1R%\x87'
target voltage 3.249V
axoloti*>
cpu : cpu functions
da : disassemble memory
debugger : debugger functions
exit : exit application
flash : flash functions
go : exit debug mode, run until breakpoint
gpio : gpio functions
halt : stop running, enter debug mode
help : general help
history : command history
i2c : i2c functions
map : display memory map
mem : memory functions
program : program firmware file to flash
regs : display registers
rtt : rtt client functions
vtable : display exceptions vector table
The tool builds a memory map for the target:
axoloti*> map
flash_main : 08000000 080fffff 1MiB flash main memory
ccm_sram : 10000000 1000ffff 64KiB core coupled memory sram
flash_opt_bank2 : 1ffec000 1ffec00f 16B flash option memory
flash_system : 1fff0000 1fff77ff 30KiB flash system memory
flash_otp : 1fff7800 1fff7a0f 528B flash otp memory
UID : 1fff7a10 1fff7a1b 12B Unique Device ID
FLASH_SIZE : 1fff7a22 1fff7a23 2B Flash Size
flash_opt_bank1 : 1fffc000 1fffc00f 16B flash option memory
...etc...
NVIC : e000e000 e000efff 4KiB Nested Vectored Interrupt Controller
SysTick : e000e010 e000e40f 1KiB SysTick
SCB : e000ed00 e000f0ff 1KiB System Control Block
MPU : e000ed90 e000f18f 1KiB Memory Protection Unit
FPU : e000ef30 e000f32f 1KiB Floating Point Unit
DBG : e0042000 e00423ff 1KiB Debug support
ROMTABLE : e00ff000 e00ff3ff 1KiB ROM Table
The tool reads the CMSIS-SVD file for the chip so it can do a full decode of the peripheral registers:
axoloti*> regs RNG *
CR : 50060800[31:0] = 0x00000004 control register
IE[3] : 0 Interrupt enable
RNGEN[2] : 1 Random number generator enable
SR : 50060804[31:0] = 0x00000001 status register
SEIS[6] : 0 Seed error interrupt status
CEIS[5] : 0 Clock error interrupt status
SECS[2] : 0 Seed error current status
CECS[1] : 0 Clock error current status
DRDY[0] : 1 Data ready
DR : 50060808[31:0] = 0xf791b09f * data register
RNDATA[31:0] : 0xf791b09f Random data
Memory dumps:
axoloti*> mem d8 flash_otp
address 0 1 2 3 4 5 6 7 8 9 A B C D E F
1fff7800: 41 78 6f 6c 6f 74 69 20 43 6f 72 65 00 00 00 00 Axoloti Core....
1fff7810: 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 08 ................
1fff7820: 50 fd 98 fa 5f fd 5e 35 1a 24 89 f3 ab e6 98 39 P..._.^5.$.....9
1fff7830: e7 7e 48 ac ab 17 6f 50 41 de 4a ed 7a 2c 48 08 .~H...oPA.J.z,H.
1fff7840: da b6 26 dd 3a d5 06 cf ed d4 e1 91 fd 79 b2 be ..&.:........y..
1fff7850: d0 97 20 03 72 01 de 8c 6e ad 5c fc 3f ab d0 dd .. .r...n.\.?...
1fff7860: 97 9b 99 e6 c3 83 37 72 da de 9e 82 32 e9 61 89 ......7r....2.a.
1fff7870: 38 4e 48 70 4b cd a6 97 cc bf 0d f3 bc 55 05 fd 8NHpK........U..
1fff7880: b1 4c 29 69 a7 ba 6f aa ad f8 31 3e 32 ec b9 60 .L)i..o...1>2..`
1fff7890: 3d 42 9f 78 98 56 ba 6d 4c 87 0c 31 91 07 af c5 =B.x.V.mL..1....
1fff78a0: 7c 90 48 28 f5 29 85 e1 14 d7 ee 34 5d be 70 57 |.H(.).....4].pW
1fff78b0: 6d 3b 67 ed 62 d5 f9 43 d4 62 97 7e e6 6e 57 4c m;g.b..C.b.~.nWL
1fff78c0: 50 03 97 88 69 63 fa f0 48 ae 8d 3e ba 74 7e 57 P...ic..H..>.t~W
1fff78d0: fc e8 af 74 75 1a 7a a1 1e 54 19 e0 20 3e 77 1e ...tu.z..T.. >w.
1fff78e0: e5 62 ba 34 85 11 35 8e 68 fa 2e 62 33 ad 9a 36 .b.4..5.h..b3..6
1fff78f0: 56 0d 9e 3a bf bb ca ab 11 d1 94 3d a9 9e 08 ba V..:.......=....
1fff7900: 64 30 7b 3e d1 9f f1 97 17 85 d0 b3 56 b6 24 48 d0{>........V.$H
1fff7910: 5e 30 9e 17 e6 c0 b4 ee 94 a7 3c 15 e8 07 ac ac ^0........<.....
Interrupt vector table:
axoloti*> vtable
priority group : pppp.... 4 bits group 3
vector table : 00000000
Name Exc Irq EPA Prio Vector
Reset : 1 - -3 080002a0
NMI : 2 - e. -2 080003c0
HardFault : 3 - -1 0801b260
MemManage : 4 - ... 0.0 0801b260
BusFault : 5 - ... 0.0 0801b260
UsageFault : 6 - ... 0.0 0801b260
SVCall : 11 - .. 1.0 080003f0
DebugMonitor : 12 - . 0.0 080003c0
PendSV : 14 - . 2.0 080003c0
SysTick : 15 - e. 8.0 080004d0
WWDG : 16 0 ... 0.0 0801b890 Window Watchdog interrupt
PVD : 17 1 ... 0.0 080003c0 PVD through EXTI line detection interrupt
TAMP_STAMP : 18 2 ... 0.0 080003c0 Tamper and TimeStamp interrupts through the EXTI line
RTC_WKUP : 19 3 ... 0.0 080003c0 RTC Wakeup interrupt through the EXTI line
FLASH : 20 4 ... 0.0 080003c0 Flash global interrupt
RCC : 21 5 ... 0.0 080003c0 RCC global interrupt
EXTI0 : 22 6 ... 0.0 080003c0 EXTI Line0 interrupt
EXTI1 : 23 7 ... 0.0 080003c0 EXTI Line1 interrupt
EXTI2 : 24 8 ... 0.0 080003c0 EXTI Line2 interrupt
EXTI3 : 25 9 ... 0.0 080003c0 EXTI Line3 interrupt
EXTI4 : 26 10 ... 0.0 080003c0 EXTI Line4 interrupt
DMA1_Stream0 : 27 11 ... 0.0 08002d90 DMA1 Stream0 global interrupt
DMA1_Stream1 : 28 12 ... 0.0 08002dc0 DMA1 Stream1 global interrupt
DMA1_Stream2 : 29 13 ... 0.0 08002df0 DMA1 Stream2 global interrupt
DMA1_Stream3 : 30 14 ... 0.0 08002e20 DMA1 Stream3 global interrupt
DMA1_Stream4 : 31 15 ... 0.0 08002e50 DMA1 Stream4 global interrupt
DMA1_Stream5 : 32 16 ... 0.0 08002e80 DMA1 Stream5 global interrupt
DMA1_Stream6 : 33 17 ... 0.0 08002eb0 DMA1 Stream6 global interrupt
ADC : 34 18 e.. 6.0 08003510 ADC1 global interrupt
CAN1_TX : 35 19 ... 0.0 080003c0 CAN1 TX interrupts
etc....
UART7 : 98 82 ... 0.0 080003c0 UART 7 global interrupt
UART8 : 99 83 ... 0.0 080003c0 UART 8 global interrupt
SPI4 : 100 84 ... 0.0 080003c0 SPI 4 global interrupt
SPI5 : 101 85 ... 0.0 080003c0 SPI 5 global interrupt
SPI6 : 102 86 ... 0.0 080003c0 SPI 6 global interrupt
SAI1 : 103 87 ... 0.0 080003c0 SAI1 global interrupt
IO Status:
axoloti*> gpio status
PA0 an tp37
PA1 an tp38
PA2 an tp39
PA3 an tp40
PA4 an tp41
PA5 an tp42
PA6 an tp43
PA7 an tp44
PA8 af0 codec_mclk, x4_2 (MCO1)
PA9 in(0) ?
PA10 in(0) s2
PA11 af10 fs_dm (OTG_FS_DM)
PA12 af10 fs_dp (OTG_FS_DP)
PA13 af0 swdio (SWDIO)
PA14 af0 swclk (SWCLK)
PA15 out(0) x3_6
PB0 an tp45
PB1 an tp46
PB2 in(0) ?
PB3 af6 x3_5 (SPI3_SCK/I2S3_CK)
PB4 af6 x3_7 (SPI3_MISO)
PB5 af6 boot0 (SPI3_MOSI/I2S3_SD)
PB6 af12 tp47 (FMC_SDNE1)
PB7 in(1) tp48
PB8 in(1) tp49
PB9 af4 tp50 (I2C1_SDA)
PB10 in(1) x3_2, x4_5
PB11 in(1) ?
PB12 af12 ? (OTG_HS_ID)
PB13 in(1) ?
PB14 af12 hs_dm (OTG_HS_DM)
PB15 af12 hs_dp (OTG_HS_DP)
PC0 an tp51
PC1 an tp52
PC2 an tp53
PC3 an tp54
PC4 an tp55
PC5 an tp56
PC6 out(0) led_red
PC7 af6 ? (I2S3_MCK)
PC8 af12 sdio_d0 (SDIO_D0)
PC9 af12 sdio_d1 (SDIO_D1)
PC10 af12 sdio_d2 (SDIO_D2)
PC11 af12 sdio_d3 (SDIO_D3)
PC12 af12 sdio_ck (SDIO_CK)
PC13 in(1) ?
PC14 in(1) ?
PC15 in(1) ?
PD0 af12 sdram_d2 (FMC_D2)
PD1 af12 sdram_d3 (FMC_D3)
PD2 af12 sdio_cmd (SDIO_CMD)
PD3 in(1) ?
PD4 out(1) ?
PD5 in(1) ?
PD6 in(1) x3_4
PD7 out(0) usb_enable
PD8 af12 sdram_d13 (FMC_D13)
PD9 af12 sdram_d14 (FMC_D14)
PD10 af12 sdram_d15 (FMC_D15)
PD11 in(1) ?
PD12 out(0) ?
PD13 in(0) sdio_cd1
PD14 af12 sdram_d0 (FMC_D0)
PD15 af12 sdram_d1 (FMC_D1)
PE0 af12 sdram_ldqm (FMC_NBL0)
PE1 af12 sdram_udqm (FMC_NBL1)
PE2 in(1) ?
PE3 af6 Codec ADC_SDATA/GPIO1 (SAI1_SD_B)
PE4 af6 codec_lrclk, x4-4 (SAI1_FS_A)
PE5 af6 codec_bclk, x4-3 (SAI1_SCK_A)
PE6 af6 Codec DAC_SDATA/GPIO0 (SAI1_SD_A)
PE7 af12 sdram_d4 (FMC_D4)
PE8 af12 sdram_d5 (FMC_D5)
PE9 af12 sdram_d6 (FMC_D6)
PE10 af12 sdram_d7 (FMC_D7)
PE11 af12 sdram_d8 (FMC_D8)
PE12 af12 sdram_d9 (FMC_D9)
PE13 af12 sdram_d10 (FMC_D10)
PE14 af12 sdram_d11 (FMC_D11)
PE15 af12 sdram_d12 (FMC_D12)
PF0 af12 sdram_a0 (FMC_A0)
PF1 af12 sdram_a1 (FMC_A1)
PF2 af12 sdram_a2 (FMC_A2)
PF3 af12 sdram_a3 (FMC_A3)
PF4 af12 sdram_a4 (FMC_A4)
PF5 af12 sdram_a5 (FMC_A5)
PF6 in(1) ?
PF7 in(1) ?
PF8 in(1) ?
PF9 in(1) ?
PF10 an power_monitor
PF11 af12 sdram_ras (FMC_SNDRAS)
PF12 af12 sdram_a6 (FMC_A6)
PF13 af12 sdram_a7 (FMC_A7)
PF14 af12 sdram_a8 (FMC_A8)
PF15 af12 sdram_a9 (FMC_A9)
PG0 af12 sdram_a10 (FMC_A10)
PG1 af12 sdram_a11 (FMC_A11)
PG2 af12 sdram_a12 (FMC_A12)
PG3 in(1) ?
PG4 af12 sdram_ba0 (FMC_A14/FMC_BA0)
PG5 af12 sdram_ba1 (FMC_A15/FMC_BA1)
PG6 out(1) led_green
PG7 in(0) ?
PG8 af12 sdram_clk (FMC_SDCLK)
PG9 af8 midi_in (USART6_RX)
PG10 in(1) ?
PG11 in(1) ?
PG12 in(1) ?
PG13 in(1) usb_flag
PG14 af8 midi_out (USART6_TX)
PG15 af12 sdram_cas (FMC_SDNCAS)
PH0 in(0) ?
PH1 in(0) ?
PH2 af12 sdram_cke (FMC_SDCKE0)
PH3 af12 sdram_cs0 (FMC_SDNE0)
PH4 in(1) ?
PH5 af12 sdram_we (FMC_SDNWE)
PH6 af12 ? (FMC_SDNE1)
PH7 af4 codec_scl (I2C3_SCL)
PH8 af4 codec_sda (I2C3_SDA)
PH9 in(1) ?
PH10 in(1) ?
PH11 in(1) ?
PH12 in(1) ?
PH13 in(1) ?
PH14 in(1) ?
PH15 in(1) ?
PI0 in(1) ?
PI1 in(0) ?
PI2 in(1) ?
PI3 in(1) ?
PI4 in(1) ?
PI5 in(1) ?
PI6 in(1) ?
PI7 in(1) ?
PI8 in(1) ?
PI9 in(1) ?
PI10 in(1) ?
PI11 in(0) ?
PI12 in(0) ?
PI13 in(0) ?
PI14 in(0) ?
PI15 in(0) ?
etc.
