Problems with the library
I just did a fresh install on my new laptop and the library is only partially there - e.g. no community patches at all.
when I try to sync sometimes I get this message:
Modifications detected : factory (1.0.12,anon)
unauthorised changes, resetting : factory (1.0.12,anon)
anyone having the same issue?
cheers
v
Did you enter your username and password for your github account that you use for the community library?
When it says "anon" it could indicate that you did not enter a username and password into the community library section and Axo editor doesn't know who you are and won't let you acces the com-lib.
hey @jaffasplaffa ,
thank you for your quick reaction,
I never had a github account before as far as I can remember, is it "mandatory" now?
btw, I created an account and tried again, but no improvements, now I get this:
Sync Successful : factory (1.0.12,vitabarba)
Sync Successful : community (1.0.12,vitabarba)
search path : C:\Users\vitabarba\Documents\axoloti\axoloti-factory\objects
search path : C:\Users\vitabarba\Documents\axoloti\objects
search path : C:\Users\vitabarba\Documents\axoloti\axoloti-contrib\objects
finished loading objects
stil very few elements in the library for me :frowning:
I also tried with older releases I got errors similar to those reported here
If you run a sync that works fine for you?
cheers,
vitaliano
I think to use the com-lib it is mandatory to have a github account. But not 100% sure to be honest. I thought it was, but if you accessed it before with out, apparently it's not.
I just did a sync library and it seems to be working fine here.
Not sure where to go from here. Maybe @thetechnobear knows more or someone else that knows more about the Axoloti system.
For now, until you get this sorted out, you can still access the com-lib objects, by downloading them directly from Github and then create your own local library folder from the Axo editor.
You can download the com-lib manually here:
I know, it's not a fix, but at least you can do some patching and have some fun while figuring the real problem out :slight_smile:
... well thank you very much, this helps already :slight_smile:
when I fisrt start after a fresh installation I actually get a long list of the modules which I will then be missing:
Axoloti version : 1.0.12-2-0-g60a2f99 build time : 08/04/2018 20:20:07 CEST
Link to firmware CRC E95BAC96
Status: factory (1.0.12,vitabarba) : OK ( 1.0.12,dirty )
Changes for: factory (1.0.12,vitabarba)
removed: objects/disp/ibar 64.axo
removed: objects/midi/ctrl/index.html
removed: objects/osc/brds/fluted.axo
untracked: objects/disp/ibar 64.axo
untracked: objects/mux/mux 8.axo
untracked: objects/midi/ctrl/index.html
untracked: objects/midi/ctrl/mpe.axh
uncommited: objects/disp/ibar 64.axo
uncommited: objects/midi/ctrl/index.html
uncommited: objects/osc/brds/fluted.axo
uncommited: objects/sel/sel 4l 16 8t s.axo
etc...
When I open Axoloti I get this:
Status: community (1.0.12,jaffasplaffa) : OK ( 1.0.12,clean )
Where you get this:
That might be the culprint, but not sure to be honest.
I am sorry, but I don't know what to do to fix it.
We can try tagging @johannes, the developer, maybe he knows more.
ah in fact I did not like that "dirty" :wink:
hopefully some new insight will come in the discussion.
thank you for your help so far,
cheers
I had/have the problem with the community lib not showing up...I just let the axo editor stay on for a while (about maybe 20 sec) before i open/create a new patch...then community lib shows up when i create a new patch.
My status is clean BTW if that matters, and i did not link any github account :smiley:
Status : home : OK
Status: community (1.0.12,anon) : OK ( 1.0.12,clean )
