One of my Axoloti Devices just became glitchy with USB Keyboards. Normally I used a LPD8 for it but some days ago the LPD stoped working at all after I used it with my Axoloti. Now I wanted to map another USB Devices and I realize that there seems to be a problem with the Axoloti receiving the midi data. Someone knows what it could be? I did not change anything inside, just had it at home for some time cause I was painting the enclosure. After that this problem showed up. Can it also be that the LPD got destroyed by the Axo in some way?
the pots to the analog in are working as usual...
