Hi!
I'm trying to load a patch from the sd-card using the patch/load object and a button but the axoloti disconnects when I trigger it.
I get the following message:
Control transfer failed: -9
Disconnect request
What am I doing wrong?
The file I'm trying to load is on the card (I've checked the file manager) and the filename and extension is also correct. My board is v1.0 with firmware 1.0.0.1, build 1.0.7 and I'm using win 10.
