Preset Manager with axocontrol
#41
Hey again @DrJustice
I did test the deglitcher again, with a wavetable patch. I have now succesfully used the deglitcher with a wavetable patch. It silences the output as supposed. Immediate does give som clicks but 0.02 works well and only silences the output for a short while, removing the blib :wink:
I had not set it up correctly at my last test. So sorry for the misinformation, I didnt remember correct. Now we dont have to worry about switcing table content in a live situation, were blibs and unwanted stuff can be pretty devastating.
This one works(you have to supply your own WT's, though. You can easily create some with my wavetable creator from com.lib. patches section):
test_deglitcher 4 WORKS.axp (15.7 KB)
It is the wavetable player from my wavetable patch... Which needs to be updated now with this little gem :slight_smile:
THANKS
#42
Yes, the immediate mode will give the type of click that you get from immediately cutting off and starting audio, but as you say, no glitches.
Thanks for testing! :slight_smile:
