...the interesting thing about a glide function is, that you can reproduce complex movements with very few controls.
here an example with the Axo control in mind: I use the three Buttons for load and safe and stepping thru 7 presets: using a binary display with the leds x00 0x0 xx0 00x etc. I could set the crossfade/ glide time and morph from one state to the other. A random function would make it even more interesting, because you could wildly change much more parameters than accessible as controls outside the box and save settings you like. Those parameters which cannot glide switch.
I used to have a similar system in my supercollider live setup and it was the hit for live performances, you can move forward with your music and glide back to a live saved preset
