Preferences - MIDI INPUT
Drop down Midi input menu - you can select one entry (v marked), click OK gets saved in prefs, but if you go and select a different input the previous one is still active and has no v mark, and only one selection gets saved in prefs
Is this normal/expected to have many selections?
macosx10.7.5
Routing MIDI through the Axoloti editor was implemented before the Axoloti firmware exposed a (class compliant) MIDI device port. You can send MIDI from other application directly to this port, routing MIDI through the editor is no longer needed. This preference/setting is already removed in git.
