Sorry if this has been anserwed but I can't find the answer ...
I want to use my AXOControl as a DIN5 controller only (nothing plugged in any usb port, processor barely used as it only serves as 10 midi out objects computing).
Is 7.5v / 0,150 Amp enough? (1.125 watt)
If not (and assuming 7.5v) what is the lowest current that will work?
Thanks
