hi!
does anyone know how to have pwm out (to power leds) only on Pin PA0?
it exists only together with Pins PA0, PA1, PA2, PA3 as the object gpio/out/**pwm t5**. but when i use that object, i cannot use the Pins PA1, PA2, PA3 anymore to read potis, which i have connected to them.
does someone maybe have an additional object to do that?
greetings
f
Possible to have pwm only on PA0?
Fib
Paulus
I have stumbled across this trouble. It's possible and rather easy to modify one existing object (for an example gpio/out/pwm t5) to only output pwm on one pin (here pb0).
If I remember well, it is as easy as erasing the line of code that concerns the pin you don't want to use with pwm), in the Init code and the K-rate code.
See these two screenshots, simply remove the selected lines and save the new object with a new name in your library.
