Hi you all,
Please do not take the title of this post wrong the wrong way. I love my Axoloti! Untill now it is everything I dreamed of
..... right up to the moment when I try to go polyphonic!
That one aspect bugs me so much that I decided to not put this post under the long running thread for patcher / GUI improvements since it would then probably just boil under.
For let's be honest: Polyphony is implemented in a very cumbersome way. One would normally want to program directly in the instrument screen, so that one can still tweak parameters that will not receive a dedicated hardware or MIDI controller directly, using the computer as a live in-depth controller besides the available board inputs an / or a MIDI controller, so to speak.
In stead one must create a polyphonic subpatch containing a list of all the parameters one still wants to tweak. That is much like doing the same work all over again while still being forced to leave the logic of the visual structure of your design behind. As a reward you then end up with a stupid “written” parameter list that also eats up extra processing power (allthough probably not very much).
My first attempt to go polyphonic today was a thud anyway because the above instrument, which works perfectly as a monophonic, does not compile propperly into a polyphonic instrument. And I do not have any idea at all what I did wrong.
Which brings me to another big disadvantage. Some of the finer programming specifics, including this one, even stay sketchy after days of wading through the community. It’s like calling that Japanese 80ties synth user-guide writer long distance yourself every time you need to do something vaguely sophisticated. “Excluse me Sil but I do not undelstand. I wolk at shiplment.”
Ah well. At least that is something that will pass.
Anyway. My main pleas are:
Plaese, please, please cure this problem. At least make it possible to tweak more then one monophonic Axoloti from one and the same base screen. I would even be prepared to buy one Axoloti per voice and just drive them on different MIDI channels. Such a setup would eat mixer inputs like there is no tomorrow but at least one could set up the sort of direct access system I describe above. At the same time it would also solve any processing power issues
Please, please, please, somebody at least produce a good guide about using polyphony as it is.
And also please write one about implementing MIDI expression. How for instance to do a sort of standard MPE module hookup with the instrument reacting to the MIDI essentials (pitchbend, modulation wheel, velocity, aftertouch).
Did I already say PLEASE?!
Marc
