Hi!
deirdre.axp (83.4 KB)
I've finished a polyphonic factotum patch. It started off life as a standalone version of the launchpad triggered patch I made before, but without the launchpad/midi stuff. But then I had the idea to make it polyphonic...
It works like this - you select how often it triggers, when it triggers and how long it triggers/loops for, all in 16ths. The actual recording the factotum uses for each trigger is determined by a dial. 0-31 on the dial will record small slices, unquantized. 32-64 will record quantized in 16ths where 32 = 1x16th, and 64 = 16x16ths.
It has an internal clock but should automatically sync to incoming midi clock/start/stop messages from an input you choose (I think I left it listening to clock from the usb device input, but it's easily changed).
The factotum has a bunch of controls scaled how I liked them. It goes into a lo pass filter. It's 6 voice polyphonic (you can choose how many voices it uses on the fly) and has controls to spread out the pitch/stretch of each factotum voice, and to spread out the filter cutoffs for each voice.
Hope you like it!
