Hey I just got this TouchMe MIDI controller that measures resistance rather than capacitance to send MIDI notes. I've been able to get it working on my laptop fine, but it doesn't work with the axo. I was wondering if anyone had any recommendations for it. Any help would be super appreciated. When I plug it in, this is what comes up in the log:
USB Device Attached
PID: 4293h
VID: 20A0h
Address (#1) assigned.
cfg desc: num interfaces 2
interface: interface 0, num 0, numep 0, class 1 , sub class 1
interface: interface 1, num 1, numep 2, class 1 , sub class 3
endpoint: interface 1, ep num 0, addr 1
endpoint: interface 1, ep num 1, addr 81
Manufacturer : Playtronica
Product : TouchMe
Serial Number : N/A
Enumeration done.
This device has only 1 configuration.
Default configuration set.
Switching to Interface (#1)
Class : 1h
SubClass : 3h
Protocol : 0h
USB Host Output size requests : 8
USB Host Input size requests : 8
USB Host Output connected to 1 : 1
USB Host Input connected to 1 : 81
MID class started.
Here is a link for it: https://shop.playtronica.com/touchme
It looks like it's sending power to the TouchMe, but it's not recognizing my touch on the main pads that send the notes. I can, however, touch the smaller buttons to change the note and scale, but that's it.
