I'm tring to build a "dj" filter like found on pioneer mixers or software like traktor.
Basically if you turn to the left it'a low cut and to the right a high cut filter.
Since SVF has outlets for all the filter moders I thought it's a nice one to use it for building it.
Here is what I got:
dj filter 2_0_1.axs (5.6 KB)
It kind of works but I have 2 problems:
There is a little tick when going from middle position to the left. It propably comes from switching from one filter to the other. I tried smoothing on both the filter mod input and the crossfade between lp and hp but that didnt really work.
When using a hp the range doesn't go up to 20khz. I believe this was a common problem with axolotis filters, and I wonder if anyone has fixed it maybe?
I currently busy working on a way of massively increase the pattern size of a seq object that has only 16 steps.
