Hello !
is there anyone able to help with this
i need to make a simple polyphonic midi loop that will just play endlessly when power is on, i found these modules and it works great in live mode and connected to computer, but when i "upload it as a startup" it doesnt load the pattern from memory, what is wrong there ? the prefix / suffix ?
i just need one sequence that will load when switched on and then play until switched off.. the axocontrol thing is there just for testing now..
thank you a lot !
