Hi - a bit boring but hopefully you have some time to comment.
generatedobjects/patch.java
- Are these functions that draw the graphics?
- How is this file related to the axoloti/patch.java? i didnt look at common functions tbh
- the code that follows "static AxoObject ..", I don't understand what is the purpose of it. Is it just for descriptions or is it important for the object to work correctly?
I am assuming that certain functions do belong in the code of an axoloti object, but I am also suspecting that my outlet/inlet string has an important function that I am entering into the name of the object - and it luckily gets parsed correctly. I think I should tidy it up and add proper a proper if function to apply char * to the data of the inlet.
