I've made a patch based on the wave/play object, triggered by a midi/in object. I copied some raw (.wav) files on the sd card, in a folder with the name of the patch.
When I'm connected with the software, I manage to trigger the files' streaming with my midi keyboard connected to the midi IN of the Axoloti Core. Everything's fine.
In the patch, I select "upload to sdcard as startup", then disconnect the Core, then power up the Core with a DC adaptator to play the patch on standalone mode.
Even though I didn't change anything in my hardware setup (midi cables, midi channel, audio cables, mixer) from the previous situation, I can't trigger any sound from the axoloti Core.
Windows 10
Axoloti 1.0.10
Did I miss something ?
PS : I tried "upload to sdcard as startup" with a synth patch, it worked fine.
PPS : I ran a SD benchmark on my SD Card ; seems fine.
