hello, i can't find a complete example how to get this working. i want to use the axo as soundprocessor for my diy aluminum-uprightbass type of thing. i need to be able switch between 3-4 patches during the gig (ext arduino midicontroller or axo-buttons). no need for the patches to run at the same time because there is a reverb afterwards in the chain. could someone pls give me some hints for the basics? where to store the controller object+ dir-info? what to put in it (besides the actual audio objects) what must be in the masterpatch, what proper file extensions? i see that if i store patches on the sdcard it makes the dirs with the name of the patch and inside a file "patch.bin" im so far that i can load one patch with a button...but not the others. ...( the axoloti is phantastic, love it definitely ....though a bit hidden in secrets ) yann
Patch select with buttons or poti firmware vers 1 (linux)
yannk
i now have createt an object, i suppose for the controller object which has gpio digital in for 6 buttons, each connected to a patch/load object. must i save it as axp or axs? the field for thr controller object does not let me choose a file, so what is the correct path+extension there? the compiler gives me a message:
"Using controller object: /patches/chooser1/chooser1.axp
Unable to created controller for : /patches/chooser1/chooser1.axp"
so its unable to do...what?
